GRE Tunnels for voice and data
May 21st, 2007
Hi All,
I have a new requirement and as per the attached diagram I need to set up two gre tunnels to the same destination with two different throughput i.e. site A and Site B will have a tunnel with 768 Kbps for voice and 256 Kbps for data.
Lets say subnet x.x.x.x for voice and y.y.y.y for data.I need help in getting the best out of a 3640 running 12.0 and another 7200 vxr running 12.0(13). Please give some inputs.
Thanks in advance
subra4u
spremkumar Mon, 05/21/2007 - 20:27
If you are sure that you are not going to use more than 256K for voice then you can configure the same way you have posted out here and configure rate-limit on both the tunnels for the maximum allowed bandwidth so that they dont choke the whole bandwidth available over the main link..
For configuring rate-limit you can refer the below link ...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080760d90.html
regds
subra4u Wed, 05/23/2007 - 00:14
Hi Prem,
Thanks for the Immediate Response, We are planning to have Voice for 768 Kbps but as for as the tunnel goes it will be like a data packet between our own custom developed servers.
Thanks & Regards
mheusinger Wed, 05/23/2007 - 03:49
There are some possibilities for voip and data over tunnels.
1) IF the packets pre-tunnel are marked (DSCP, IP precedence) then the GRE headers will also get the same markings. You can then setup a policy on the physical interface towards the internet to prioritize voip.
2) You could use "qos pre-classify" on both routers - newer IOS required though afaik.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a0080087f3c.html
3) use one tunnel and a nested policy.
Why do you need two tunnels?
regards, Martin
