System Bootstrap
Answered Question
May 21st, 2007
How do you upgrade the system bootstrap on a 2620? I have a router w/ System BootStrap Version 11.3(2)XA4 and another w/ System Bootstrap 12.1(3R)T2.
Where do I find the software at?
Correct Answer by CSCO10892433 about 9 years 10 months ago
Hi, Brian
I'm not sure it is possible to upgrade the bootstrap by software. But I know it is easier to replace the BootRom with one which has the version 12.1. You can find many such BootRoms on the ebay. The following page is just one of them.
http://cgi.ebay.com/NEW-BOOTROM-CISCO-2620-2621-MEM2620-32FSBOOT-2600-BOOT_W0QQitemZ320115241371QQihZ011QQcategoryZ67292QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
SSLIN
Overall Rating: 5 (3 ratings)
Correct Answer
CSCO10892433 Mon, 05/21/2007 - 20:02
  • Silver, 250 points or more
Hi, Brian
SSLIN
