Port Address Translation w/ PIX 515E
May 21st, 2007
Does anyone know if it is possible for a PIX 515E to do simple Port Address Translation (PAT)? Also, how many concurrent connections that would sustain?
Johnny
acomiskey Mon, 05/21/2007 - 09:36
  • Green, 3000 points or more
global (outside) 1 interface
nat (inside) 1 0 0
vitripat Mon, 05/21/2007 - 09:37
  • Gold, 750 points or more
Yes its possible to do PAT on PIX. Here is an example-
nat (inside) 1 0 0
Above commands will simply PAT all the inside network when going outbound to the IP address on the outside interface of PIX.
Here is a link which will help you understand hot NAT/PAT is configured and works on PIX-
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/bafwcfg.html#wp1112345
Hope this helps.
Vibhor.
laurent.geyer Mon, 05/21/2007 - 11:48
Is this what you're talking about?
Translate a.a.a.a TCP/80 to b.b.b.b TCP/8080
If so, you would accomplish it as follows:
static (, ) tcp a.a.a.a 80 b.b.b.b 8080 netmask 255.255.255.255
