expect hash payload, got payload#: 11
Answered Question
I have numerous IPSec VPNs via my PIX Version 6.3(5)working.
A new tunnel is being set up and the connection is not being made.
What is a payload # 11 ?
The pertinent debug messages are
ISAKMP (0): beginning Main Mode exchange
throw: mess_id 0x0
send_response:
isakmp_send: ip xx.xx.xx.xx, port 500
ISAKMP msg received
crypto_isakmp_process_block:src:xx.xx.xx.xx, dest:yy.yy.yy.yy spt:500 dpt:500
gen_cookie:
fill_sa_key:isadb_search returned sa = 0x38045ac
validate_payload: len 212
valid_payload:
ISAKMP_INFO exchange
process_isakmp_info:
error - IKMP_MODE_FAILURE
return status is IKMP_NO_ERR_NO_TRANS
Thanks.
Jacob
Correct Answer by zulqurnain about 10 years 1 month ago
hello,
also beside as suggested check the acl's on both FW, both side acl's should match in a reverse order form.
HTH, please rate it
Overall Rating: 4 (1 ratings)
mchin345 Fri, 05/25/2007 - 13:55
  • Silver, 250 points or more
it seems that phase 1 negotiation is failing.
The logs show that after the PIX sends out the first MM isakmp packet, it never sees anything back from the remote peer.
Possible reasons:
1. make sure the isakmp policy is matching the other side.
2. make sure the preshared key is set correctly.
3. make sure there is no device in the middle blocking UDP/500 packets.
Correct Answer
zulqurnain Sat, 05/26/2007 - 05:13
  • Bronze, 100 points or more
hello,
HTH, please rate it
