Connect 2 locations over Gigabit Ethernet
May 21st, 2007
I would like to connect the LAN?s of 2 location with each other. the provider deliver a gigabit Ethernet between location A and location B. I have in the first location a Catalyst 6000 and in the second location a catalyst 3750G. Is there a document for this example ? what I must follow ?
Nouri
spremkumar Mon, 05/21/2007 - 19:04
  • Red, 2250 points or more
Hi Nouri
Are you going to have extended LAN kinda facility or going to have 2 different setups and want them to communicate over this link connected on the ethernet ?
regds
NBouassiba Tue, 05/22/2007 - 01:35
I want to setup a LAN-interconnection between
the locations ( 500 meter between building A und building B ). The LAN in the old building
is based on the catalyst 6000 ( SUP1A and msfc1), in the new building I will install a catalysts 3750G. I want to setup a inter VLAN
routing in the new builing and allow the inter VLAN routing with the old LAN.( see attachement)
ankbhasi Tue, 05/22/2007 - 01:41
  • Cisco Employee,
Hi Friend,
You have to configure intervlan routing on 3650 switch in new building. So on whichever 3750 you want to have intervlan routing make sure you first create all vlans at layer 2 which are in new building as well as old building.
Like vlan 20,30,40,etc etc should be created forst on that 3750.
Once you are done just configure layer 3 interfaces for all those vlans something like
interface vlan 20
ip address
interface vlan 30
ip address
and in same way for all vlans for which you want inter vlan routing and then assign respective clients in their vlan the gateway ip address what you will configure on all layer 3 interfaces.
Ankur
*Pls rate all helpfull post
