Terminal Anomaly When Connect to Pix Remotely
May 21st, 2007
Sorry for my English,
I'm using putty for remote connections and I have an issue when i connect to a pix 515E. I can connect without problem using SSH but when a type "sh run" the configuration is displayed completely; is displayed continuously from begin to end without pause. I compare with a backup config and don't find any changes.
If some one have this issue too and Know how can i solve this the help will be apreciated.
laurent.geyer Mon, 05/21/2007 - 13:32
The command you're looking for is `pager lines '. It's possible that the pager lines configuration was removed for one reason or another.
I found `pager lines 60' to work well for me, `pager lines 24' is the default.
pedrosuero Mon, 05/21/2007 - 14:34
Thanks for the help, thats the command. I already be verified before, but i don't see anything estrange. That line was in the config.
Anyway like you said for some reason this config was removed, i just putting again an it works like before.
a lot of thanks.
