Trunk between Cisco 3825 and Avaya S8500 PBX
Hello All,
I am new in VoiP field so I definitely need your help here. I want to connect these two devices together using QSIG trunk. PBX uses E1 card and Cisco uses VWIC-2MFT-E1-DI card, physically connect by RJ48 cable. If it works, this router will be act as a gateway for other two CME router from the remote sites. The problem is that I can never make the E1 interface come up. Could anyone point me to the right direction? Here is the configuration on the router
R3825#
network-clock-participate wic 0
network-clock-select 1 E1 0/0/1
isdn switch-type primary-qsig
voice service voip
qsig decode
controller E1 0/0/1
clock source line primary
pri-group timeslots 1-31
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
paolo bevilacqua Mon, 05/21/2007 - 19:44
  • Hall of Fame,
    Founding Member
is the controller up? You probably also need clock internal and isdn protocol-emulate network.
Thanks for your reply.
The controller is down. I did try enter these two commands, but it still shows down
clock source internal
3825#show controllers e1
E1 0/0/1 is down.
Applique type is Channelized E1 - balanced
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20060623, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (397 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 397 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
