NM-HDV2-1T1/E1 Not working
May 21st, 2007
Hi all,
I just received a brand new 2811 with a NM-HDV2-1T1/E1 module to be connected to an E1 ISDN PRI interface.
However, the integrated E1 interface just can?t establish the ISDN framing with the PBX. I inserted a VWIC2-1MFT-T1/E1 into this module, configured the port and voila! the ISDN framing came up right away.
So... it seems the integrated port on the module is DOA, but since this is a new module to me I want to be sure I?m not missing something before requesting a RMA.
Am I missing something besides issuing the card type e1 command?
Thanks in advance
paolo bevilacqua Mon, 05/21/2007 - 16:32
  • Hall of Fame,
    Founding Member
HI, can you check if the settings are the same for impedance and crc ?
carlosv Mon, 05/21/2007 - 16:39
Thanks for taking your time.
Yes, both are the same. All the config is exactly the same except for the port number. I use the cables to the PBX for both ports. The DSPs are ok and I can assign them to both cards.
wflores@its.co.cr Mon, 05/21/2007 - 17:29
Hi Carlos
T1/E1 cards need the IOS release 12.4.
You first must enable the of the card as E1 then I will be able to configure like a normal E1.
When you look the card is like totally dead but is not.
HERE SOME PART OF THE CAPTURE, when I worked with this kind of card.
version 12.4
hostname CCME_PQ
boot-start-marker
boot-end-marker
card type e1 0 2
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
controller E1 0/2/0
pri-group timeslots 1-31
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
REGARDS
WALTER FLORES
carlosv Wed, 05/23/2007 - 09:20
Thank you Walter,
However, the configuration with the VWIC card is working, what I need is to know how to make it work with a single NM-HDV2-1T1/E1 without an extra VWIC card. This is the relevant configuration:
card type e1 1 0
card type e1 1 1
network-clock-participate slot 1
network-clock-select 1 E1 1/0
isdn switch-type primary-qsig
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-8,16
controller E1 1/0/0
framing NO-CRC4
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn send-alerting
no cdp enable
interface Serial1/0/0:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
voice-port 1/0:15
cptone DE
timeouts interdigit 30
timeouts wait-release 3
voice-port 1/0/0:15
cptone DE
The controller E1 1/0/0 is the VWIC port, E1 1/0 is the integrated port. If I plug the PBX cable on the first one everything works great, when I change to the other one doesn't.
TIA.
