Custom IPM data?
Answered Question
May 21st, 2007
Just wondering if its at all posible to access IPM statistical data for the creation of our own personalised graphs and reports?
Correct Answer by Joe Clarke about 9 years 9 months ago
Sure. With IPM we publish the database schema. While you won't get TAC support for custom applications, you can certainly access the database to get what you need.
You should be able to find the schema in the docs subdirectory on the IPM CD-ROM.
Overall Rating: 4 (1 ratings)
Correct Answer
Joe Clarke Mon, 05/21/2007 - 16:04
