No data records in historical reports
May 21st, 2007
I recently had to run a repair on my IPCC express 4.0(4) sr01_build029. The repair went well except the historical reports have no data. The control center show in service but gives me the red x and will not let me restart it. X on SQL agent, historical and repository
bwalchez Mon, 05/28/2007 - 11:24
Restore the backed-up data to the Historical Reports Database Server manually. Alternatively, perform 1) Use a text editor to open this file: C:\program files\WFAVVID\ wfengine.properties.(This file may be in another folder if you did not install Cisco CRA in the default folder.) 2) Add 1000 the value of this property: com.cisco.wfframework.engine.APPLICATION_TASKID_BLOCK
Save the wfengine.properties file. 3) Use a text editor to open this file: C:\program files\WFAVVID\ application.properties. (This file may be in another folder if you did not install Cisco CRA in the default folder. 4)Add 1000 the value of this property: com.cisco.session.id.block 5)Save the application.properties file.
dcasto Tue, 05/29/2007 - 12:59
I will try the restore tonight. I could not find either one of the files (wfengine.properties or application.properties)though.
