05-21-2007 06:35 PM - edited 03-03-2019 05:05 PM
I have installed WIC-2T card into 3620 (64MB DRAM) router. When i run "show ip interface brief" or "Show run" command, there is no serial interface available. But when I run "show diag" command on cisco IOS it is showing the WIC-Card information. I m using IOS version 12.3. can anybody help me to solve this problem ?
Solved! Go to Solution.
05-21-2007 07:53 PM
Hi, ictforall
WIC-2t is not supported on NM-1E2W. You need an NM-1FE2W to support wic-2T. Or you can use WIC-1T instead on you NM-1E2W module.
SSLIN
05-21-2007 06:51 PM
I think you need to configure controller card with using unframed/frame formet.
channel-group 0 timeslote 1-31.
Hope this will help you out.
-Minu
05-21-2007 07:14 PM
"card type", "controller" command is not working in config mode.
05-21-2007 07:18 PM
Can you post the output show version here ?
Also you yourself can check out whether the ios has detected the card successfully by verifying the show version output...
regds
05-21-2007 07:23 PM
show version command doesn't show the seriel interfaces. here is the output of show version.
IOS (tm) 3600 Software (C3620-IK9O3S6-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 12-Dec-05 21:59 by evmiller
Image text-base: 0x60008B00, data-base: 0x61A18000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-IK9O3S6-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Router uptime is 2 hours, 51 minutes
System image file is "flash:3620-ik9o3s6-mz.123-17a"
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 11876707
R4700 CPU at 80MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
05-21-2007 07:27 PM
Did u try reseating the card onto different slot ?
Also can you post the output of show diag here ?
regds
05-21-2007 07:31 PM
I have inserted this card in both slots. and tried in another 3620 also. but same thing happenes. here is the output of show diag.
Router#show diag
Slot 0:
Combo 1E, 2W Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision F0
Serial number 27296772 Part number 800-01789-05
FRU Part Number: NM-1E2W=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 37 01 02 01 A0 84 04 50 06 FD 05 00 00 00 00
0x10: 78 00 00 00 02 03 06 17 FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial 2T (12in1)
Hardware revision 1.0 Board revision D0
Serial number 25312114 Part number 800-03181-01
FRU Part Number WIC-2T=
Connector type PCI
0x20: 01 12 01 00 01 82 3B 72 50 0C 6D 01 00 00 00 00
0x30: 68 00 00 00 00 09 02 00 FF FF FF FF FF FF FF FF
05-21-2007 07:53 PM
Hi, ictforall
SSLIN
