static route entry
Answered Question
May 21st, 2007
hello
i would like to ask if a static route entry is visible into the routing table regardless of the existance of the link with the other side of the route.
thanks
Correct Answer by ankbhasi about 9 years 11 months ago
Hi Friend,
Nops if the exit interface link is down or the router does not know how to reach the next hop then the static route will not appear in routing table.
Ankur
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Mon, 05/21/2007 - 23:28
  • Cisco Employee,
Hi Friend,
Ankur
spremkumar Mon, 05/21/2007 - 23:29
  • Red, 2250 points or more
The existence of a static route depends on the link status through which its pointed out.
If the outgoing interface is defined at the end of the static route and if the interface is down the static route will be taken off from the routing table.
regds
batman46 Tue, 05/22/2007 - 08:52
routes are only visible if the distant end is up, the way around this would be to use the keyword persistant at the end of the static route command. this ensures that the route stays in the table even if the link is down.
