Mark Turpin Tue, 05/22/2007 - 09:35
Why not use ART to generate this information for you? I believe the gateway utilization reports will give you the detail you're looking for.
redrobish Tue, 05/22/2007 - 15:33
the problem is whenever I run the gateway utilization report, I only "Gateways with zero ports" and no data on it.
Do I need to setup something?
thanks
redrobish Mon, 06/11/2007 - 22:42
I was able to resolve it by adjusting the max port of my gateway.
thanks
