Phones doesn't register anymore on subscriber
May 22nd, 2007
I have a problem about the phones registration on CCM Subscriber.
We have tried to restart all services without obtains any results. I think the server needs to be restarted.
I attach the file containing the errors report.
Zin.Karzazi Tue, 05/22/2007 - 01:28
  • Silver, 250 points or more
DBLException Error
You see this error message in the application log of both the Cisco CallManager Publisher and Subscriber:
Error: DBLException - DBL Exception.
ErrorCode: 8
ExceptionString: Invalid parameter
UNKNOWN_PARAMNAME:Text: addDevice
App ID: Cisco CallManager
Cluster ID: XXXX-Cluster
Node ID: 192.168.0.2
Explanation: Severe database layer interface error occurred.
Recommended Action: Contact TAC..
This type of error is seen when an IP phone is rejected from registration or because of a broken subscription between the publisher and subscriber databases. This issue can be solved by using the DBLHelper tool. For more information on DBLHelper, refer to Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription.
See the link below:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801df0ed.shtml
Karzazi
mcappelli Mon, 05/28/2007 - 00:40
Nothing to do !
I have used DBLHelper but the subsribers servers has the green icon as their SQL's Database are syncronize.
jbarcena Mon, 05/28/2007 - 04:49
  • Red, 2250 points or more
Have you tried restarting the CCM service on the Subscriber? probably that service got hanged, try that, if not then further troubleshooting is needed and some traces will be needed, if you are not familiar with the traces then try rebooting the server before opening a case with us.
