Need sanity check on loop configuration
May 22nd, 2007
I've got two stacks of two 3750-E series switches, I want to create a redundant loop between the stacks via the fibre uplinks. So lets say stack one has:
switch1
switch2
And stack 2:
switch3
switch4
I'm thinking of running a multimode fibre cable from switch 1 to switch 3 and a nother fibre cable from switch 4 to switch 2, thus makinga redundant loop. My question is do I need to run a fibre cable from switch 1 to switch2 and equally one from switch 3 to switch4 or will the backbone 3750 connection take care of the switching between them?
Thanks in advance
Dan
My question is that do I need to buy fibre connecti
Amit Singh Tue, 05/22/2007 - 04:35
  • Cisco Employee,
Dan,
What is the final topology that you have. What is the distance between these two stacks.
If you want to connect these two stacks for redundancy, I would suggest to configure the links as an ether-channel link. This will give you both redundancy and load-sharing with aggregated bandwidth.If distance is not so much then you can use the ethernet cable. If you have a larger distance, then you have to buy SFP GBICS for fiber connectivity. 3750-E comes with a TWIN-GIG converter to get installed in the 10GE port and give you the SFP connectivity.
Also, if you have backbone 3750 switch in the connectivity,it depends howz the connectivity is there in the topology and the kind of config that we have, the traffic will flow accordingly.
HTH,Please rate if it does.
-amit singh
