Multicast across vlans - Catalyst 6k
May 22nd, 2007
Hi all,
Is it possible to multicast from one public vlan to another?
Setup is:
ip multicast-routing
no ip igmp snooping
interface Vlan1
description multicast are running here
ip address 1.1.1.x.x.255.0
ip pim sparse-mode
ip igmp static-group 233.62.223.2
ip igmp version 3
ip igmp snooping fast-leave
end
interface Vlan2
description I want to watch my multicast stream ***
ip address 2.2.2.x.x.255.0
ip igmp join-group 233.62.223.2
ip igmp version 3
end
When i have an ip adress in vlan 1 I can connect fine to the multicast stream - but when I'm in vlan2 I cannot connect.
Philip
ankbhasi Tue, 05/22/2007 - 06:39
  • Cisco Employee,
Hi Philip,
So you have multicast server on vlan 1 and you want to receive multicast traffic on vlan 2 correct?
Can you also configure "pim" under interface vlan 2 and see if that works?
Also can you paste the output of "sh ip mroute" once you configure pim under vlan 2?
Ankur
Harold Ritter Tue, 05/22/2007 - 07:06
  • Cisco Employee,
Also make sure the multicast source application generates the multicast stream with a TTL of at lease 2. Otherwise, the router will simply drop the packets.
Hope this helps,
benterry1210 Sat, 06/23/2007 - 03:30
I too am having the exact problem. I have added PIM and join group (as per the application), but the vlans fail to see M/cast traffic between them.
Can anyone post some configs that will allow multicasting to work between separate vlans on a 6509 IOS device?
The sh ip mroute output is:-
*, 239.255.255.254), 03:55:19/00:02:51, RP 0.0.0.0, flags: DC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan193, Forward/Sparse, 03:55:19/00:00:00 (ttl-threshold 2)
*, 239.255.255.253), 03:55:18/00:02:50, RP 0.0.0.0, flags: DC
Vlan193, Forward/Sparse, 03:55:18/00:00:00 (ttl-threshold 2)
*, 239.255.255.250), 03:55:19/00:02:51, RP 0.0.0.0, flags: DC
Vlan101, Forward/Sparse, 03:53:58/00:02:49 (ttl-threshold 2)
*, 229.55.150.208), 03:55:18/00:02:49, RP 0.0.0.0, flags: DC
Vlan101, Forward/Sparse, 02:21:04/00:02:49 (ttl-threshold 2)
*, 239.83.100.109), 02:21:15/00:02:49, RP 0.0.0.0, flags: DC
Vlan101, Forward/Sparse, 02:21:15/00:02:49 (ttl-threshold 2)
Vlan193, Forward/Sparse, 02:21:15/00:00:00 (ttl-threshold 2)
*, 224.0.1.40), 03:55:19/00:02:48, RP 0.0.0.0, flags: DCL
*, 224.0.1.60), 03:55:18/00:02:42, RP 0.0.0.0, flags: DC
*, 234.5.6.7), 03:55:18/00:02:48, RP 0.0.0.0, flags: DC
*, 224.0.1.24), 03:55:19/00:02:51, RP 0.0.0.0, flags: DC
Many thanks
