ce500 and Cisco-Voice vlan
May 22nd, 2007
Hi all,
does anyone knows if ( and how ) it's possible to connect a router ( or other client ) to a port with native vlan the Cisco-Voice ?
I've seen it's possible to bring out that vlan as tagged in a dot1q trunk, but i would like to bring out as untagged vlan.
When i try to set native ( or access ) on any port i get the message that only "ip-phone+desktop" can have that vlan.
I thought to set the voice vlan with a different name than Cisco-Voice, but when i connect a pc+ipphone ?
Many thanks in advance
Luigi
carenas123 Tue, 05/29/2007 - 06:14
  • Silver, 250 points or more
Cisco-Voice VLAN goes to the Siemens Router and the Data VLAN to the SonicWall Firewall, the situation is that the Siemens router doesn?t support Trunk Encapsulation 802.1q or VLANs.
If your network requires segregating either or both voice and guest traffic and if you create additional VLANs, you must also create following Vlans, the information are in URL :
http://cisco.com/en/US/products/ps6545/products_user_guide_chapter09186a0080531ea9.html#wp160440
