Configure 3750 in stack
May 22nd, 2007
We are thinking about putting two 3750 in stack, is there some documentation on how you should do this ?
I never done this before, is this an easy to set up ?
Overall Rating: 4.5 (2 ratings)
paramvsi Tue, 05/22/2007 - 06:01
Yes, you are right that the setup is really easy and takes only a few minutes to setup. It is same as connecting the two switches togather with a crossover cable, but there are some differences.
1. There is a Cisco proprietory cable that needs to be used whic connects the switches at the back.
2. There are special ports that need to be used to connect these switches togather to form a stack.
3. There are two configuration i.e. 1 to 1 or Ring. In a 1 to 1 stacking the switches are stack but they do not have any redundancy on link failure and the backplane on the switch stack is 16 Gbps. In case of a ring configuration you have link redundancy and also it provides 32 Gbps of backplane between the switches.
Please see the following link to find more on the stack configuration:
Manging the Stack:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swstack.htm
Stacking the switches guideline:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12237se/ol12631.htm#wp455774
Stackwise Technology:
http://cisco.com/en/US/products/hw/switches/ps5023/products_white_paper09186a00801b096a.shtml
Hope you find this useful !!
Param
tuva02100 Tue, 05/22/2007 - 23:56
Thanks alot for quick help.
do you remember what this cable is called :)
Br
-Tuva
tuva02100 Wed, 05/23/2007 - 02:58
i got a hold of the cables from our vendor :)
but i have another question, in my documentation, they refer to ios 12.2(37)SE
We run ios 12.2(25) SEB2
are they much different, and how can i check the difference between them ?
-Tuva
adavenport Thu, 05/24/2007 - 21:36
Each switch should have come with one cable.
When you attach the two together, the master switch will update the images so they are both the same. Obviously 12.2(37) is the newer of the two, but there is little difference that you will notice.
Roger
