SSH issue
yjdabear
This is after deleting the previously stored key from
/home/myid/.ssh/known_hosts.
debug1: sending SSH2_MSG_KEXDH_INIT
debug1: expecting SSH2_MSG_KEXDH_REPLY
debug3: check_host_in_hostfile: filename /home/myid/.ssh/known_hosts
debug3: check_host_in_hostfile: filename /etc/ssh_known_hosts
debug2: no key of type 0 for host router1
debug3: check_host_in_hostfile: filename /home/myid/.ssh/known_hosts2
debug3: check_host_in_hostfile: filename /etc/ssh_known_hosts2
debug2: no key of type 2 for host router1
The authenticity of host 'router1 (10.1.5.9)' can't be established.
RSA key fingerprint is 22:e3:6d:c1:12:be:0e:63:4c:77:0c:b5:67:74:c5:ae.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'router1,10.1.5.9' (RSA) to the list of known hosts.
debug2: bits set: 507/1024
RSA_public_decrypt failed: error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
debug1: ssh_rsa_verify: signature incorrect
key_verify failed for server_host_key
debug1: Calling cleanup 0x2d2e4(0x0)
There's no hardware change on the Cisco device.
"show cryp key mypubkey rsa" looks fine.
Never mind, turns out no SSH server is running on the router.
8 Replies 8
Joe Clarke
Just FYI, when troubleshooting SSH, the first thing I typically do is telnet to TCP port 22 on the target device. This allows me to confirm, first, that SSH is running, and second what protocol version is being used:
1.5 : The device only supports SSHv1
1.99 : The device supports both SSHv1 and SSHv2 (RME will use SSHv2 to communicate with the device)
2.0 : The device only supports SSHv2
In this case, it's answering on port 22, but "show ssh" indicates there's no SSHv1 or v2 server running.
%No SSHv2 server connections running.
%No SSHv1 server connections running.
The issue : RSA_public_decrypt failed: error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
is related to the cisco router. The RSA key are corrupted and you cannot connect on the router with a ssh client in SSH V2
To fix it
  • Enable telnet access on the router
    enable
    conf t
    line vty 0 4
    logging synchronous
    length 0
    transport input telnet ssh
    line vty 5 15
    logging synchronous
  • Suppress the RSA key present on the router by the telnet access
    enable
    conf t
    crypto key zeroize
  • Add a domain name on the router
    enable
    conf t
    ip domain-name XXX.YYY.com
  • Create a new key RSA pair
    enable
    conf t
    crypto key rsa modulus 2048
  • Reboot the router
since a router, don't forget a "wr mem"
I know this is an old post but wanted to add the solution that worked for me.
I attempted @Ipsnetwork Fix, to no avail.
The Fix:
conf t
crypto key generate rsa mod 2048 label <label_name>
ip ssh rsa keypair-name <label_name>
Can you send the output of the following commands:
sh ver | in image
sh ip ssh
(you can skip the RSA key hash area of the "sh ip ssh" output, since you shouldn't share that online.
@normanksmith  I had a bit different error but this solution fixed the issue.
This label technique fixed for us too.
Thanks Norman.
