QoS & DMVPN
I have hub& spoke DMVPN configuration.
After upgrading IOS on my 3800 routers from 12.4.1T1 to 12.4.11T1, the Qos configuration stops working. When I applied the "service-policy output OUT to the multilink interface, I got the message "qos suspeneded.." on my hub routers. The spoke routers do not have that problem.
class-map match-any PLATINUM-OUT
match ip precedence 5
policy-map OUT
class PLATINUM-OUT
priority 2400 1000000
class class-default
int multilink 1
Thank you very for your help.
bjornarsb Tue, 05/22/2007 - 22:45
  • Bronze, 100 points or more
Its a bug:
CSCsg83151: DMVPN: QOS enabled on physical outbnd interface stops packet forwarding
This could also be the case even if the say that its detected on a 1841.
CSCek61004: (DMVPN) : Packets arent classified correctly in policy-map
BR,
Bjornarsb
