Phone load for 7931G help
May 22nd, 2007
Can someone help me with the correct syntax for the 7931G phone load in CCME
I can't get the phone to select the correct phone load. Right now is selecting term31.default, but I want to specify the correct phone load. I downloaded the 7931 file from Cisco's website but the phone does no take it.
Any ideas
Here is my syntax
Armando
File from Cisco CME-7931_8-1-1SR2RN_SCCP.tar extracted to flash
tftp-server flash:apps31.8-1-0-89.sbn
tftp-server flash:cnu31.8-1-0-89.sbn
tftp-server flash:cvm31sccp.8-1-0-90.sbn
tftp-server flash:dsp31.8-1-0-89.sbn
tftp-server flash:jar31sccp.8-1-0-90.sbn
tftp-server flash:SCCP31.8-1-1SR2S.loads
aramos17428 Tue, 05/22/2007 - 21:15
The configuration is still being imported by QCT so all I have connected at this point is 3 phones ( 1 7941 and 2 7931G. I'm running CME 4.1 which supports the 7931G and the phones are coming up and registering. However, i would like to select the correct firmware for the phone, term.31 as firmware seems to me like default phone load and not the correct one for 7931G SCCP. With the 7940 and 7960 I know how to do it but with the 7931G the file extension are different and do not know which is the correct one.
Thansk
Armando
John Clark Tue, 05/22/2007 - 21:44
try adding the following
conf t
telephony-service
load 7931 SCCP31.8-1-1SR2S
create cnf
then reset the phone.
