Germany Dialing Plan Problem
This is my first post so bear with me on this.
I am currently having a problem with my CallManager configuration.
We are running Cisco Unified CallManager 4.2 configured for a North American Dialing plan but we are using it as the CallManager for our Munich office in Germany.
We are experiencing problems with the amount of digits that the local Telco is pushing. Sometimes they push 11 and sometimes they push 12. Whenever I created a translation pattern for 11 digits it works, but when a 12th digit comes in the translation patter will only match and work for 11 digits.
Here is an example:
Here is some basic information:
089 7504 090 <~~ Main Number
089 7504 0901 <~~ Main Fax
When the user calls
089 7504 09015
The translation patter will find a match on the 11th digit (1) and will send the local Telco a stop signal.
Is there a way to work around this?
Thank you,
pwellmann Mon, 02/18/2008 - 03:01
While reading Cisco Unified Communications SRND (based on CUCM 6.x), I found a mistake or misunderstanding in Cisco document:
"It is possible to use route patterns instead of translation patterns to block calls within the line calling search space
The main difference between using a route pattern and a translation pattern to block calls is the end-user experience when trying to dial a blocked number, as follows:
• When using a translation pattern, the end users will be able to dial the entire number and only then will they hear a fast-busy tone.
• When using a route pattern, the end users will hear a fast-busy tone as soon as the number they are dialing can no longer match any allowed pattern. This behavior assumes an IP phone running SCCP, or an Type-B IP phone running SIP with no SIP dial rules configured in the phone."
Refer to: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1046180
In CUCM 6.x, translation pattern come along with implicit enabled Urgent Priority.
That makes sense...
littledavewhite Tue, 10/14/2008 - 12:06
Did you find a way around this issue, i will be rolling a gateway out in Munich attached to a UCM cluster in the UK. i noticed the variable length numbers for fax, i thought it was a mis print, is this common in Germany ?
Keith Fulcher Wed, 10/15/2008 - 02:03
Germany does not have a set digit plan like the States. They can vary depending on the Block bought from the Carrier.
iptuser55 Wed, 10/15/2008 - 04:13
  • Silver, 250 points or more
Do you have H323 gateways, the same issue is in Austria , Italy and Luxembourg
You need to create a Translation rule for them
rule 1 /^4090$/ /123/
rule 2 /^4090./ /4090./
Create a dummy DN for the main number so rule 1 will pick out the exact match 4090 and send it to the DN
Rule 2 is - may be needed, maybe not allows the other calls through without a translation, the idea is that it will wait until is check the translations first
The 4090 is dependant on the number of digits you receive from the Telco
ruttersean Fri, 02/27/2009 - 08:08
I just completed a CME deployment in Germany.
I had the same issue I believe.
I needed to enable overlap-receiving on each of my BRI channels:
isdn overlap-receiving
MICHAEL BASTINCK Fri, 02/27/2009 - 11:23
For Germany I had to implement the isdn overlap-receiving T302 2500 timer, so my gateway have some extra time to receive all the digits
littledavewhite Fri, 02/27/2009 - 11:53
Hi I found the best way was to convert to H323 and use translations it worked a treat.
voice translation-rule 1
rule 1 /^29921191$/ /1900/
rule 2 /^2992119\(.+\)/ /19\1/
voice translation-profile incoming
translate called 1
put the rule on the voice port incoming so it works in srst also
1900 is the ops and the other numbers are DDI and FAX. As you can see the ops number is less digits than the ddi.
hope this helps
dave white
ccie#13955
