Interface Card and Network Module
May 22nd, 2007
what is the difference between Interface Cared and Network Module?
I want to terminate 16 T1 as the 3800 series router will it be possible to have 16 or more T1 termination at the same router 3800?
spremkumar Tue, 05/22/2007 - 19:43
  • Red, 2250 points or more
Hi Dangal
As far as the slots are concerned you can easily have 16 T1 connections.
You have the options of 4 WIC slots and 4 NME slots where you can place 4 WIC-2T and on the NME slots you can place the combinations of NM-2W and wic cards on that ..
By doing so i feel you will be able to connect 16 T1 lines onto your Cisco 3845 router..
regds
