VPN client through local PIX to remote concentrator
May 22nd, 2007
I'm sure that this has been asked before, but...
I have a VPN client behind my PIX 515E going to a remote site with a 3000 series concentrator. I can establish the tunnel, and though my client can send packets it never receives any back. I need another set of eyes or brains on this as I'm stumped. Any ACL suggestions?
Remote NAT traversal is not the problem here, btw, as the client is not NATing or PATing anything... And, I know that it's my PIX as I can connect from home.
pstebner1 Tue, 05/22/2007 - 12:32
Mr. Comisky - nice to hear from you again!
Here are the relevant portions of my config:
PIX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password xxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxx encrypted
hostname ciscopix
domain-name xxxxxxxxxxxxxx
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol dns maximum-length 1500
fixup protocol ftp 21
fixup protocol ftp 6055
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol snmp 162
fixup protocol sqlnet 1521
fixup protocol tftp 69
name Inside_LAN
name LIS
name dmz
access-list outside_inbound_nat0_acl permit ip Inside_LAN
access-list inside_access_in permit ip any any
access-list inside_access_in permit udp any any
access-list inside_access_in permit tcp any any
access-list inside_access_in permit icmp any any
access-list 101 permit ip Inside_LAN
logging on
logging buffered informational
icmp permit any inside
icmp permit any dmz
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside ww.xx.yyy.zzz
ip address inside
ip address dmz
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
global (outside) 1 interface
global (dmz) 1
nat (outside) 0 access-list outside_inbound_nat0_acl outside
nat (inside) 0 access-list 101
nat (inside) 1 Inside_LAN 0 0
static (dmz,outside) ww.xx.yyy.xzz LIS netmask 0 0
access-group inside_access_in in interface inside
access-group dmz_in in interface dmz
route outside ww.xx.yyy.zzx 1
timeout xlate 0:30:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
sysopt connection permit-l2tp
sysopt noproxyarp inside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
acomiskey Tue, 05/22/2007 - 12:43
Nothing wrong there, might as well get rid of access-list inside_access_in as it's just permitting everything anyway. You say you are not nating or pating clients but you are pating Inside_LAN to ww.xx.yyy.zzz.
pstebner1 Tue, 05/22/2007 - 12:47
I opened up that access-list for troubleshooting purposes. Also, I am using PAT but the remote site is not, and that may or may not be where the problem lies. My VPN client is getting a class-B public address from these guys.
acomiskey Tue, 05/22/2007 - 15:06
I assume you're also nating again on an outside router? Also, it shouldn't matter whether or not the remote end is running PAT, it is only significant that you are on the local end. Just make sure the checkbox on the concentrator is checked for NAT-T and you can rule it out as a problem.
pstebner1 Tue, 05/22/2007 - 19:56
They won't verify NAT-T is checked, but they say that they have hundreds of other clients using this VPN without issue. Also, I can get in from home and I am NATing there. It has to be something on my PIX, but I'm dumbfounded... Any other things that you can possibly think of?
srue Tue, 05/22/2007 - 20:10
Can you check it from other PC's inside your network where you're having the issue? Can they even verify that you log in to the vpn? Also, on the 300x concentrators, they should be able to see TX/RX traffic on a per user basis. Install a sniffer on your PC and see if it verifies what you're finding.
and like a previous poster stated, you can get rid of the inside access list, since you've allowed everything outbound. you're just causing more processing overhead on the PIX.
if you have a "permit ip any any", you dont need a "permit tcp/udp/icmp any any" because they all use IP, and hence those ACE's will never be matched.
--one last thought on your vpn issue, check split tunnelling. verify the address you're trying to connect to on the other end of the vpn is being transmitted through the tunnel, and not your local network.
pstebner1 Wed, 05/23/2007 - 06:42
It is definitely a problem for all machines. Split tunneling is not being used in this case.
The access-list was a test - it is not what I would normally use.
I will try the sniffer idea - I have Ethereal on my laptop already.
pstebner1 Wed, 05/23/2007 - 07:09
The concentrator is at a remote client site and I have no access to it. All they will tell me is that it works for everyone else.
acomiskey Wed, 05/23/2007 - 07:23
Add this and give it a try, if this doesnt work then nat-t is not an issue as you have suggested.
fixup protocol esp-ike
Also, what device is outside your pix?
pstebner1 Wed, 05/23/2007 - 08:20
I tried that and got:
PAT for ESP cannot be enabled since ISAKMP is enabled. Please correct your configuration and re-issue the command!
Also, my network goes switch -> PIX -> 2691 router (no access-lists except for telnet)
acomiskey Wed, 05/23/2007 - 08:26
I guess it's telling you to remove isakmp nat-traversal, although I don't think this will solve you problem anyhow.
Another thing I noticed in your config is your nat exemption. You can remove the following
This is not needed as your acl 101 is bidirectional and you are not nating on your outside interface anyway.
pstebner1 Wed, 05/23/2007 - 08:40
Ah, good call. I just inherited this a short time ago and hadn't noticed that...
