2500 booting problem!
May 22nd, 2007
My 2500 routers are all failing to boot up to the end. They all start well and aterwards, freeze. The other one shows that it has been restarted shortly after press "Return to start!"
Please help me.
Overall Rating: 5 (1 ratings)
Wilson Samuel Wed, 05/23/2007 - 04:27
Hey,
It looks like an altogether different reason, BTW have you checked your Scroll Lock button, if its ON (LED will be lit and will show under the Hyperterminal also) the screen simply freezes!!!
I hope that helps,
Please rate if it does help.
Kind Regards,
Wilson Samuel
vmzyece1977 Tue, 05/29/2007 - 17:27
Your solution was helpful and it did work have since posted my rating, you got a 5.
Now, I configured all my 3 routers and a switch well. All my interfaces are up and when I do "show CDP neighbors", I see other routers but cannot ping them successfully. Do you know why I am failing to ping them?
Vc
vmzyece1977 Wed, 05/30/2007 - 12:08
Hey guys!!
I solved the problem and it feels good to finally be on a working network.
Thanks to you all for your support.
Vc
