05-22-2007 12:47 PM - edited 03-05-2019 04:13 PM
I upgrade my 3560 to 122-25.SEE2 and the command dot1x pae authenticator is present under my interfaces. What is this command for? I didn't understand the explanations that I have found.
05-23-2007 08:32 PM
Hello thomas
this command is just an informational command added prior to 12.2-25SEE.. whenever you enable dot1x globally, and enable it on the interface with the "dot1x port-control auto" command, this command just adds up , by default. this just shows that it has enabled the authenticator functionality on the port. so, i really dont think you need to bother too much about this command :)
Hope this helps.. all the best . rate replies if found useful..
Raj
05-24-2007 07:11 AM
If I remove dot1x port control auto from the interface, should I remove the dot1x pae authenticator
05-24-2007 03:30 PM
Hello thomas,
Yes. it is a good practice to remove the unused commands, if you arent using it :) you can knock off the pae authenticator command if you arent using dot1x :)
hope this helps. all the best. rate replies if found useful.
Raj
05-25-2007 07:14 AM
thank you
