IP Communicator over VPN with ASA5500
I've just changed a PIX506E by an ASA5505. After that I've got some troubles with remote IP Communicator clients connecting by VPN. They can connect on the VPN and register their IP Communicator, but they're not able to make calls. When the New Call button is pressed nothing happens. It seems it could not pass skinny signaling over VPN.
The inspect skinny and inspect tftp command are configured under global policy map.
If a come back to the PIX, everything works fine.
Has someone seen that before?
thanks in advance
Overall Rating: 5 (1 ratings)
ggilbert Tue, 05/29/2007 - 08:58
Have you tried to take out the skinny and tftp inspection out of the policy - Did it make any difference?
