SRST with Unified Messaging 4.21 intergration
Set up SRST with a few FXO ports.
Assume that in SRST mode
What Try to accomplish is that:
1. when user press message key, it will go their voice mail box.
2. If ext:1001 call ext:1002, it should go to 1002 voice mail box, so 1001 can leave voice mail.
3. If outside user call ext 1002, it should go 1002 voice mail.
I can make 1 work, but not 2 and 3.
I post my confgure here:
trunk group westfxo
voice call send-alert
voice rtp send-recv
voice service voip
h323
no h225 timeout keepalive
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice-port 0/0/0
trunk-group westfxo 1
connection plar opx 1002
caller-id enable
voice-port 0/0/1
trunk-group westfxo 2
caller-id enable
dial-peer voice 1 pots
trunkgroup westfxo
incoming called-number .
direct-inward-dial
dial-peer voice 11 pots
trunkgroup westfxo
destination-pattern 911
forward-digits all
dial-peer voice 12 pots
trunkgroup westfxo
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 13 pots
trunkgroup westfxo
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 14 pots
trunkgroup westfxo
destination-pattern 9011T
prefix 011
dial-peer voice 22 pots
trunkgroup westfxo
destination-pattern 91646xxx8280
prefix 1646xxx8280,,,
dial-peer voice 31 voip
destination-pattern 1...
voice-class codec 1
voice-class h323 1
session target ipv4:10.0.6.12
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 32 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.0.6.11
no vad
dial-peer voice 33 pots
trunkgroup westfxo
translation-profile outgoing toHQ
preference 2
call-manager-fallback
secondary-dialtone 9
max-conferences 1 gain -6
transfer-system full-consult
ip source-address 192.168.245.33 port 2000
max-ephones 336
max-dn 960 dual-line
after-hours block pattern 1 91900T
system message primary West Fallback
dialplan-pattern 1 646xxx1... extension-length 4
transfer-pattern .T
voicemail 91646xxx8280
call-forward pattern .T
call-forward busy 91646xxx8280
call-forward noan 91646xxx8280 timeout 10
moh music-on-hold
vm-integration
pattern direct * CGN
pattern ext-to-ext no-answer # FDN #2
pattern ext-to-ext busy # FDN #2
pattern trunk-to-ext no-answer # FDN
pattern trunk-to-ext busy # FDN #2
At the unity opening greeting, I set caller input "#" Send caller to Caller System Transfer.
I think I need to match DTMF tone with Unity setting, but dont know how.
Already open a ticket with tac, they said I might hit a BUG... I am running 4.21 without any patch.
I am sure someone did this kind of intergration before.... please help...
Ken
kelvin.blair Tue, 05/22/2007 - 14:24
  • Silver, 250 points or more
What version of IOS are you running? There is a redirect bug in some of the older IOS. Extension to extension was not effected, but Trunk to Extension was effected.
Try this and I think it may help. Create a dialpeer that matches the number called to get voicemail. In this dialpeer make sure you do a "forward all extra inband". This will forward DTMF inband. One of the problems you will have is stripping the 9 off the outbound call. You need to create a translation rule that strips the 9. It should look like this:
voice translation-rule 80
rule 1 /\(^91646\)/ /1646\2/
voice translation-profile VMout
translate called 80
translation-profile outgoing VMout
trunkgroup westfxo
destination-pattern 91646xxx8280T
Let me know if that works for you.
Thanks for respond.
The verison is c3825-spservicesk9-mz.124-3f.bin
I am not sure there is bug at the router, coz the tac told me that the dtmf tone get inside the unity (he use "call viewer" and "port status monitor"). I can see "#" and the extension was entered into Unity.
Now, they tried to figure out how to make the opening greeting to accept those dtmf tone.
I got debug voice ccapi inout at router:
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=91646xxx8280#1002 --->1001 call 1002
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=1002 --> forward number
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Well, I am all ears... hopefully someone done this kind of intergration before... please let me know..
Ken
Problem solved by tac, so I am going to share the solution.
trunkgroup westfxo
destination-pattern 916461234567*.... <--*.... match
your 4 digit dialing plan and * match vm-intergration
prefix 16461234567,, <-- ,, is pause
voicemail 916461234567
call-forward busy 916461234567
call-forward noan 916461234567 timeout 10
vm-integration
pattern ext-to-ext no-answer * FDN #2
pattern ext-to-ext busy * FDN #2
pattern trunk-to-ext no-answer * FDN #2
pattern trunk-to-ext busy * FDN #2
So basically, if noone answer, it will call unity 16461234567
Here is the digit send to unity during opening greeting:
1. send pause
2. send * FDN --> extension 5100
3. #2 (skip the greeting: "I am transfering to extension 5100").
3. goes into 5100 subscriber greeting directly.
Ken
