CCIE-SP Available Dates - ?
May 22nd, 2007
Hi:
Not sure if this is the right place to ask such a question but I am trying to schedule and pay for the CCIE-SP Lab but am unable to see any available dates for RTP. The system reports that there are no available lab dates: if you try for June or July or any other month.
This does not make any sense at all :-(
How can I get this done?
Thank you.
Sincerely.
swaroop.potdar Tue, 05/22/2007 - 14:26
  • Blue, 1500 points or more
You can try the steps below,
1) Keep checking frequently, as more new/dropped dates may be available.
2) Write to CCIE-Support Team and check with them the status of dates.
3) Post your query in the Certification section.
4) Last option is to just wait for the dates. :-)
HTH-Cheers,
Swaroop
westford Tue, 05/22/2007 - 17:25
I met the same problem, please give me an upate once you got the answer.
Ricky
frenzeus Fri, 05/25/2007 - 09:38
  • Bronze, 100 points or more
I would say that the seats are fully booked in all 5 lab locations worldwide. When i was looking thru it in Jan/Feb, all 5 lab locations had seatings available till year end. AFAIK, for RTP i recall seeing seats available only in Dec07, but that was in April. Again, the only way is to keep checking back on the website.
