2948 CatOS switch help
May 22nd, 2007
All, Ive never seen a 2948 CatOS switch before. Im wanting to create a trunk port to another Cisco switch. How would I go about doing that on the 2948 CatOS switch? Thanks.
Overall Rating: 4 (2 ratings)
mohammedmahmoud Tue, 05/22/2007 - 14:15
It should be something like this:
set trunk 0/1 on
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud Tue, 05/22/2007 - 14:26
set trunk 0/1 on
Mohammed Mahmoud.
glen.grant Tue, 05/22/2007 - 16:04
You can use this too "set trunk desirable dot1q" . Vtp domain names must match and the switch on the far end must be set to desirable or auto for trunking . If the far end is IOS " " switchport mode dynamic desirable "
