Richard Burts Tue, 05/22/2007 - 17:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
robert
The 2521 has a Token Ring and ISDN interfaces which probably will not do you much good. It has 2 regular serial interfaces and 2 sync/async interfaces which are useful. You certainly should be able to configure this as a Frame Relay switch.
I am not sure that I can say that I have done this with a 2521, but many times I have configured routers in the 2500 series with 2 serial interfaces as a Frame Relay switch. They work quite nice for this.
Good luck with it.
Rick
