using a CSS to manage a socket port failure
May 22nd, 2007
I have a client/application that is making a direct persistent TCP/IP connection between itself and a socket handler runing on address 1:port 1111. What I want is, if this conenction fails, when the client tries to reconnect, if the port is unavailable then the server to failover to a secondary port. Other connections on address 1 ports 1112-9999 should be unaffected. Is this possible? Do I have to configure keepalives for this to work or will it automatically detect the lost of the connection?
Any help you can give me would be appreciated!! Thanks in advance.
sbilgi Tue, 05/29/2007 - 06:33
The topology must not balance packets in a TCP/IP socket connection across more than one Ethernet port on the have configured a permanent port using the (config) flow permanent port command, the CSS sets the flow timeout value to 0, which means that the flow should never time out.
