Jon Marshall Tue, 05/22/2007 - 22:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
As far as i know you can't do this on the FWSM. SSL v3.0 and SSL v2.0 will both use port 443 and that is the only control you have on the FWSM. There is no "fixup" specifically for HTTPS which means the FWSM does not have an any application aware code for the version of https being used.
Basicaly you need to ensure that you are not running v2.0 SSL on any of your servers if you are concerned with the security vulnerabilities.
Jon
