How to add the cisco meetingplace express service?
May 22nd, 2007
hi,all
i've installed the cisco meetingplace express 1.2 and now i want to use the Cisco Unified MeetingPlace Express Service for our phone 7940 to attend the meeting.How to add the service on callmanager ? my ccm version is 4.2,thanks.
bwilmoth Mon, 05/28/2007 - 13:32
The Cisco Unified MeetingPlace Express service for the Cisco Unified IP Phone is available only to Cisco Unified IP Phones that are registered to Cisco Unified CallManager. Cisco Unified CallManager Express does not support the Cisco Unified MeetingPlace Express service for the Cisco Unified IP Phone.
Enter the URL in one of the following formats, where server is the hostname or IP address of the Cisco Unified MeetingPlace Express system:
. If SSL is enabled on the system:
http://server/MPAPI/ipphone/login?serverhost=server
. If SSL is not enabled on the system:
http://server:8080/MPAPI/ipphone/login?serverhost=server:8080 .Note This URL is case sensitive.
Make sure that this server remains independent of the servers in your Cisco Unified CallManager cluster. Do not specify a Cisco Unified CallManager server or any server that is associated with Cisco Unified CallManager (such as a TFTP server or directory database.
Page no 101 of http://www.cisco.com/univercd/cc/td/doc/product/conf/mpe/v12/admin/cmg/cm12_bk.pdf
kelvin.blair Tue, 09/11/2007 - 07:13
I've added the above information, but can't seem to make it work. I'm running CM 4.2.3 with MPLACE 1.2. Service is applied to a phone with username, and pin information. The PIN information is the same as USER PRofile password correct? The message that I get when attempt to login is you are not authorized to login. This is the same message if I do not include any username and password params in the service configuration. SSH is enabled for the server, because I can ssh to the box with putty. I got to be missing something stupid. Can someone offer some suggestions?
