PIX 515 and VLANs
May 22nd, 2007
I have a PIX 515 with 3 FE's (DMZ included). I have a switch behind the DMZ interface where the servers are connected to.
What I would like to do is to have 2 VLANs (1 for MGMT and 1 for Data), so I can manage the switch in a separate VLAN.
Question is whether I can do that, and what the sample configs would look like.
satoshi.takano Tue, 05/22/2007 - 20:04
Looks like I'll need to use dot1q trunking. It's a 3Com 4200 switch which claims that it does support. I need to make sure that the PIX can support that.
Jon Marshall Tue, 05/22/2007 - 23:15
Don't know bout the 3com's but 802.1q is an industry standard and this is encapsulation that the pix uses so as long as the 3com is not doing something "different" than the standard you should be okay.
