05-22-2007 07:46 PM - edited 02-21-2020 03:04 PM
Remote VPN users have established IPSec VPN connection with the VPN Concentrator. The option "Check to use internal address pool configuration to obtain an IP address for the client" is checked on the VPN Concentrator
If I split the existing single DHCP IP address range pool into 2 or 3 pools in the same subnet, will the existing VPN client sessions terminate?
05-28-2007 01:33 PM
yes, it may terminate existing VPN client. check this bug-id :CSCef03321
06-11-2007 08:48 PM
Thanks a lot for the feedback.
