SSH Requires a user login?
Answered Question
May 22nd, 2007
Am changing over some of our switch configuration to use SSH instead of Telnet.
Does SSH require they you supply a username at login? or can you remove this prompt?
Dan
Correct Answer by spremkumar about 10 years 1 month ago
Hi Dan
You need to supply a user name followed by the password configured for the same.
AFAIK I dont think you have any options to remove out the same..
regds
Overall Rating: 4 (2 ratings)
Correct Answer
spremkumar Tue, 05/22/2007 - 23:23
  • Red, 2250 points or more
Hi Dan
regds
