HSRP and IPv6
May 23rd, 2007
Iam working on a project to role out IPv6 to our network. We use HSRP to provide resilience to our customers instead of using BGP between us and them. Looking at the below link HSRP for IPv6 only allows a virtual Link local address is it possible to use a Global address instead. PS does anyone know when HSRP for IPv6 will be available on the Cat6500/720sup.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_configuration_guide_chapter09186a008078f345.html#wp1067254
Kind Regards
Kev
carenas123 Wed, 05/30/2007 - 05:45
  • Silver, 250 points or more
It is not possible to use a global address. With the latest supervisor engine ie., sup32pisa support for IPV6 HSRP is available
kjbarrass Wed, 05/30/2007 - 05:54
Cheers for that, were using SUP720 so will have to look at using static link-local addresses for IPv6 HSRP, need to read up on any possible drawbacks of using link-local addresses on a service provider network.
Kev
leon.mflai Tue, 09/20/2011 - 12:41
Hi all,
Knowing that it seems Cisco ISR-G2 still doesn't support HSRP IPV6 with Global IP address. Is there any clue or does Cisco has any plan to implement this feature on ISR-G2?
Tks
Leon
