router 2600 bus error
May 23rd, 2007
I am getting the following error after starting up the router: any help will be appreciated.
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 24576 Kbytes of main memory
bus error while trying to access flash - addr = 0x60000000
cannot read flash info
getdevnum warning: device "flash" has size of zero
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
rommon 1 >
Overall Rating: 5 (1 ratings)
dgoodridge Wed, 05/23/2007 - 02:17
I know it's stating the obvious but you've got a problem with the flash.
On most devices these errors can occur after a failed IOS upgrade and in some extreme cases (although not normally on a modular platform) require the whole chassis to be replaced.
However, it could equally be something very simple like the flash module has become unseated. If you are confortable to do so, then remove the cover and check the seating (presence) of the flash module. If that doesn't yield any progress then try swapping the flash module with a spare and try again.
Hope that helps.
Doug
