05-23-2007 12:53 AM - edited 07-03-2021 02:06 PM
I am having a problem getting hot standby to work. I have two AP1130AG and as far as I can see they have been setup identically.
When I turn on Hot Standby it fails to initialise. When I check the log I see the following messages:
Warning Interface Dot11Radio0, cannot associate: EAP authenticating
Error Unable to start supplicant on Dot11Radio0
Warning Interface Dot11Radio1, cannot associate: EAP authenticating
Error Unable to start supplicant on Dot11Radio1
I'm not sure how the AP authenticate each other!
Any help on resolving this problem would be much appreciated.
Phill
05-30-2007 05:53 AM
This error message is associated with the client association. It has not got to do anything with EAP. Make sure the backup APs are on same subnet as the monitored APs.
05-30-2007 07:00 AM
The backup AP is on the same subnet as the monitored AP. The clients do not have any problems connecting to the primary access point. The settings as far as I can tell are indentical as recommended from all of the white papers I have read.
Do you have any other suggestions?
