WAFS Unlocked .doc File
May 23rd, 2007
We are testing the solution WAFS(4.0.9.b.10) by Cisco with a CM, edge and core devices(WAE-612-K9) in WCCP Mode (latence 100ms, line 2Mb/s). We open in remote a 10Mo Word document shared(with Word 2002 SP3), we save it after modification. During saving, you try to open the same document directly from the server (or Core LAN), just before the end of saving. Incredible, we can open it and remote saving is blocked.
Do you know if it's a WAFS Cisco Unlock bug or Microsoft?
Thanks a lot.
Best regards.
