05-23-2007 02:43 AM - edited 07-03-2021 02:06 PM
Is there a conflict when a laptop has an active Ethernet cable connected and available wireless 802.11b/g connection? If so, which technology would take over?
Thanks.
Solved! Go to Solution.
05-29-2007 05:53 PM
Hilarious. No network connectivity 'takes over' based purely on the connection type!
This is simply a question of the ip routing table ('netstat -rn') and which order you get connected and if an ip address is assigned, etc.
For example, if you are on working wireless network and then plug in a wired cable to an active network and get a DHCP address, without disconnecting from the wireless network, you will actually be connected to both networks. The default gateway (the 0.0.0.0/0 route in the routing table) will have a lower metric for the connection that happened second, or the wired connection, which means all traffic not destined for your local (directly connected) wireless or wired network subnet will be sent to the wired network's default gateway.
I use this to my advantage during my consulting work by utilizing cellular or guest wireless network for my default route so my VPN client (etc) works, while being able to print locally, etc. This is not the most secure way of doing things, but it works and I hope answers your question...
05-29-2007 09:51 AM
First, there will not be any conflict with having wired and wireless connection on the same PC. From my experience, I think wired connection will take precedence over wireless connectivity.
05-29-2007 05:53 PM
05-30-2007 01:42 AM
I had never thought about the routing metric to determine which interface gets used, that is very useful information.
However what happens if both the Wired and Wireless interfaces are connected to the same subnet, i.e. the network in Bridged not Routed? Will the host transmit on the First connected interface, the fastest, the first listed in ipconfig, or is it completely random?
