Multicasting - no RP assignment of multicast range
May 23rd, 2007
Trying to run multicast (PIM-sparse-dense) over a LES100 connection, but though I have an IP PIM neighborship establised across it both ways, I do not see the PIM-Group to RP mappings at the far end. The same configurations have been applied to numerous LES1000 (not LES100) circuits with no issues, with the only exception of a Layer 2 only (Catalyst 2940)terminating the LES100 circuit.
I haven't exceeded my TTL boundary.
Any ideas what I should look for?
Thanks in advance
Edison Ortiz Wed, 05/23/2007 - 06:16
You should look for RPF (Reverse Path Forwarding) failures between the mapping agent and the affected device.
'show ip mroute count' should indicate for any RPF failures.
From your diagram, I can't tell how the unicast routing looks like.
You can also enable debugging against mpacket on the 4500 and 3560.
'debug ip mpacket'
paul-giles Thu, 05/24/2007 - 06:12
Thanks for your comments.
Carrying out a debug ip mpacket on the 4500, I see it reports "not rpf interface" for the loopback of the RP, 147.184.15.244
May 24 13:45:18: IP(0): s=147.184.15.244 (Loopback0) d=224.0.1.40 id=49391, ttl=28, prot=17, len=48(48), not RPF interface
however the rpf check from the 4500 and traceroute look OK.
4500#sh ip rpf 147.184.15.244
RPF information for stvndcc02.ggr.co.uk (147.184.15.244)
RPF interface: GigabitEthernet3/1
RPF neighbor: ? (147.184.53.21)
RPF route/mask: 147.184.15.244/32
RPF type: unicast (ospf 11000)
RPF recursion count: 0
Doing distance-preferred lookups across tables
Tracing the route to stvndcc02.ggr.co.uk (147.184.15.244)
1 147.184.53.21 4 msec 0 msec 4 msec
2 147.184.53.10 0 msec 4 msec 0 msec
3 147.184.53.30 0 msec * 0 msec
What could be causing the "not rpf interface"?
Harold Ritter Thu, 05/24/2007 - 07:49
Paul,
Is PIM configured on the loopback interface? If not, this could be the issue.
Hope this helps,
paul-giles Fri, 05/25/2007 - 04:52
Hi - Here are the configurations.
3560
interface Loopback0
ip address 139.136.4.246 255.255.255.255
ip pim sparse-dense-mode
4500
interface Loopback0
ip address 147.184.53.250 255.255.255.255
One of the downstream RP Switches which is not shown in the diagram.
6500
interface Loopback0
ip address 147.184.15.246 255.255.255.255
ip multicast ttl-threshold 32
ip multicast boundary 20
ip ospf cost 2
logging event link-status
access-list 20 permit 224.0.1.39
access-list 20 permit 224.0.1.40
access-list 20 permit 239.192.0.0 0.0.255.255
As you can see, we set a site boundary and TTL scoping for this MAN.
Edison Ortiz Fri, 05/25/2007 - 06:42
Every device on the path has PIM enabled on their interfaces ?
I'm referring to this path:
Also, ip multicast-routing in the global config ?
paul-giles Fri, 05/25/2007 - 07:14
Hi - All L3 interfaces have ip pim sparse-dense-mode configured and multicast is globally configured.
