Accessing voicemail from another users phone - CME
Answered Question
May 23rd, 2007
Voicemail pilot number 1000
Is there a way to configure cme/cue to access your voicemail from another persons phone, I notice by default when you dial into voicemail it uses the extension you dial from to check whether there is a mailbox and if so asks for a password.
Is there a way to enter the voicemail box number you want to check
Thanks in advance
Correct Answer by Brandon Buffin about 10 years 2 months ago
Yes, when CUE picks up, press *.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 05/23/2007 - 04:06
  • Purple, 4500 points or more
Brandon
mark_gardner Wed, 05/23/2007 - 05:12
Excellent exactly what I was looking for.
You wouldnt happen to have a link to that Brandon ?
Many Thanks
Mark
