the Ap 1242 always reboot when it receive a Image from WCL 4402
May 23rd, 2007
hi all,
when i config WCL 4402 like:
IP on Management Interface: 172.16.1.1 255.255.255.192
dhcp: 172.16.1.1
IP on AP-Management interface: 172.16.1.2 255.255.255.192
dhcp: 172.16.1.1
i make scope on WCL: 172.16.1.20 - 172.16.1.40
i connected WCL4402 and AP 1242 to a switch. when i turn on AP1242, it receive
a Image from WCL4402, but it always reboot
here is some message:
Mar 1 00:00:36.731: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 172.16.1.20, mask 255.255.255.192, hostname AP001b.0cfb.d91a
*Mar 1 00:00:49.074: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:49.074: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 1 00:00:49.074: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar 1 00:00:50.074: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:50.074: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*May 23 02:42:09.204: %LWAPP-5-CHANGED: LWAPP changed state to CFG
*May 23 02:42:14.229: LWAPP_CLIENT_ERROR_DEBUG: spamHandleCfgReqTimer: Did not recieve the Config response
*May 23 02:42:14.300: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE.
*May 23 02:42:14.300: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
flashfs[0]: 8 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 4946432
flashfs[0]: Bytes available: 11052544
flashfs[0]: flashfs fsck took 26 seconds.
Base ethernet MAC Address: 00:1b:0c:fb:d9:1a
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.123-11.JA/c1240-k9w8-mx.123-11.JA"
can everybody help me?
i attach a file.
thanks!
you can send by email for me.
my email: [email protected]
For the past three days I've been trying to figure out what sounds like the exact same issue. I have two 1242's that continue to register with the 4402 controller only to reboot within 5-30min. When the AP's are up and registered clients connect and seem to work just fine - until the AP reboots. Here is the console output of one of my AP's booting up.
AIR-LAP1242AG-A-K9
%SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar 1 00:00:07.091: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar 1 00:00:08.680: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar 1 00:00:09.841: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar 1 00:00:09.850: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(3g)JA, RELEASE S
OFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 27-Apr-07 02:17 by pwade
*Mar 1 00:00:09.851: %SNMP-5-COLDSTART: SNMP agent on host HOPKINTON-01 is unde
rgoing a cold start
*Mar 1 00:00:09.869: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar 1 00:00:09.902: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 1 00:00:09.929: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning freque
ncies for 22 seconds
*Mar 1 00:00:10.721: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar 1 00:00:10.869: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar 1 00:00:10.902: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar 1 00:00:11.721: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar 1 00:00:28.868: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:28.896: bsnUnlockDevice: not bring radio up: radio 1 is in admin d
isable state
*Mar 1 00:00:29.095: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:29.357: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 1 00:00:29.386: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:29.405: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Mar 1 00:00:29.406: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 1 00:00:29.434: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:30.386: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar 1 00:00:38.013: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned D
HCP address 10.117.52.101, mask 255.255.255.0, hostname HOPKINTON-01
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
*Mar 1 00:00:49.371: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve
*Mar 1 00:00:59.397: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:59.398: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
*Mar 1 00:00:59.398: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Mar 1 00:01:00.398: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 28 17:04:01.245: %LWAPP-5-CHANGED: LWAPP changed state to CFG
*Jun 28 17:04:01.291: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
*Jun 28 17:07:50.000: %LWAPP-5-CHANGED: LWAPP changed state to UP
*Jun 28 17:07:50.045: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 28 17:07:50.102: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jun 28 17:07:50.109: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Jun 28 17:07:50.143: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 28 17:07:51.144: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
cpetroff Tue, 08/07/2007 - 20:45
I recently ran into this same problem. In debug mode on the WLAN Controller I found the following:
Tue Aug 7 23:28:52 2007: 00:12:7f:6e:21:63 AP 00:12:7f:6e:21:63 not allowed to join. Regulatory Domain check completely FAILED. Allowed: (802.11bg:-AB 802a:-AB)
Tue Aug 7 23:28:52 2007: 00:12:7f:6e:21:63 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:12:7f:6e:21:63 slot 0
Tue Aug 7 23:28:52 2007: 00:12:7f:6e:21:63 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:12:7f:6e:21:63 slot 1
Tue Aug 7 23:28:52 2007: 00:12:7f:6e:21:63 Deregister LWAPP event for AP 00:12:7f:6e:21:63 slot 0
Tue Aug 7 23:28:52 2007: 00:12:7f:6e:21:63 Deregister LWAPP event for AP 00:12:7f:6e:21:63 slot 1
Further checking showed that my AP did not seem to have a controller for dot11. I opened the 1231G, reseated the radio card (it was obviously not seated well) and powered it back up. The AP joined without any further issues.
--Chris
