CSM 3.0 problems on loading IPS-K9-6.0-1-E1 sw version
May 23rd, 2007
Dear all,
I am facing many problems with loading IPS Sensors softwrae release onto Cisco
Security Manager (CSM) - IPS MANAGER vers.003.000 (004).
I have loaded my IDSM-2 (IPS-K9-6.0-1-E1 sw version) via Client of CSM 3.0,
selecting "Add New Device" / Catalyst 6500 IDSM, IPS, target OS Version 5.1 (the tool doesn't me allow to choose target OS later than 5.1 !)
But when I make a Query to the sensor (on IPS MC), I get this message:
Version detected on the sensor is 6.0(1)E1V1.2. Current version in MC is 5.1(1)S206.0.
Out-of-band changes may have occurred. Please re-import configuration. "
Ihave downloaded the latest signatures IPS-CS-MGR-sig-S288-req-E1.zip from cisco.com.
But as soon as I try IPS Manager/Configuration/Update Network IDS/IPS
Signatures/Submit, and then select IPS-CS-MGR-sig-S288-req-E1.zip on the scrollbar I
get "Object update failed. Unknown update type. "
I appreciate so much your help on this matter !
Thanks a lot.
jbayuka Tue, 05/29/2007 - 09:56
When trying to apply the signatures you will have to use the .zip and not the pkg. this is one reason why you are getting the " Object update failed. Unknown update type MC " error
