Network Infrastructure
May 23rd, 2007
We are using one 7206 router as a gateway router and others 3600,2600 routers besides them.Sudden interrupt in 7206 like power cutoff caused all the originating routes to disappear.So routes are then not advertised by ospf.Does our infrastructure incorrect or it happens always.What is the solution we can have other that static routes or the network infrastructure.
spremkumar Wed, 05/23/2007 - 20:19
  • Red, 2250 points or more
Hi Sagar
You have just mentioned about 3 routers here you need to throw more clarity on how many links are getting connected and how your wan topology is being designed.
Pictorial diagram representing the connectivity and the boxes will be of gr8 help in suggesting the best way out..
regds
