switchport mode multi
May 23rd, 2007
What happen if I connect one switch port configured with "switchport mode multi" to another switch? broadcast strom? like spanning-tree loop? Can you give me some comment?
Best Regards,
Jackson Ku
Overall Rating: 4.7 (4 ratings)
bjornarsb Wed, 05/23/2007 - 06:04
  • Bronze, 100 points or more
mode multi ??, what type of switch is this ?
Bjornarsb
mheusinger Wed, 05/23/2007 - 06:15
  • Green, 3000 points or more
afaik this was a "special" feature on 2900XL and 3500XL switches to connect routers and servers, but NOT switches or Hubs. Have a look at "Overlapping VLANs and Multi-VLAN Ports"
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swvlan.html#wp1028684
You should not connect such a port to another switch. Basically per-VLAN spanning tree will not work properly and loops could result (assuming redundant topology).
Hope this helps!
Regards, Martin
jackson.ku Wed, 05/23/2007 - 07:19
Can you explain "Basically per-VLAN spanning tree will not work properly and loops could result"? I do not clearly understand it.
Best Regards,
Jackson Ku
ankbhasi Wed, 05/23/2007 - 08:00
  • Cisco Employee,
Hi Jack,
A multi-VLAN port functions normally in all its VLANs. For example, when an unknown MAC address is received on a multi-VLAN port, it is learned by all the port in those VLANs.
Multi-VLAN ports also respond to the STP messages generated by different instances of STP in each VLAN. Because the multi-VLAN port is a member of more than one VLAN, flooded traffic received from the multi-VLAN port is forwarded to ports in all VLANs assigned to the multi-VLAN port.
So in short there can be multiple unpredictable results so I will recommend you not to connect it to switches or hub.
Ankur
*Pls rate all helpfull post
ankbhasi Wed, 05/23/2007 - 06:26
  • Cisco Employee,
Hi Jack,
Cisco will never recommend you to connect multi mode switchport to any other switches or hubs, it is recommended to connect these switch to routers or servers only.
It may result in broadcast stroms when loops are created and may result in loss of connectivity also.
Have a look at this link and there is a caution mentioned for multi vlan switchport usage
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/cli/clicmds.html#wp1057945
Ankur
Wilson Samuel Wed, 05/23/2007 - 06:33
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
I practically ran into a big issue when I used mode multi.
Infact it was used on 2900 Series Switches long back whenever we wanted a port to support multiple VLANs and ofcourse in those days the L-3 Switches were quite rare and expensive.
These days I guess with 3560s around we can easily do the same stuff with L-3 routing.
Kind Regards,
Wilson Samuel
