my first switch conf
remarkit
Hi All,
I prepare the CCNA and got recently a couple of 2950 and 3550 switches to use as a lab. I have never been in a cisco switch before. I have problems getting a telnet connection working.
Here is what i have done so far:
hostname switch1
line vty 0 15
login authentication default
ip default-gateway 10.2.255.254
interface Vlan1
ip address 10.2.10.200 255.255.0.0
no shut
interface fastEthernet 0/1
switchport mode access
I still cant ping the switch or access it via telnet. I have plugged a crossover cable from fa0/1 to the wall.
show ip interfaces switchport:
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
What am i missing?
16 Replies 16
Richard Burts
Alan
Right now the biggest issue looks like this line:
If the interface is down then there is no connectivity. My first guess would be a cable issue. Depending on what you are connecting to, I would suggest trying a straight through cable and see if that works better. When you say that you connected to the wall, what does that mean? What is connected to the wall?
There might be some other things that cause this, but lets examine the basic connectivity issues first.
Rick
Rick
Also check to see that the device you are using to connect is in the network 10.2.0.0 255.255.0.0
I have plugged my switch to the Ethernet outlet in the wall, that outlet is then connected to the server room on another switch (via a panel)to the last router.
I just tried a straight-through cable but the result is the same.
Alan
Thanks for trying the other cable. If the connection is going to be switch to switch then crossover is probably the right choice.
At this point I would like to try to narrow down where the problem is happening. If you plug a laptop or PC into the Ethernet outlet in the wall (with a straight cable) do you get link on the PC? This will help tell whether the problem is on our side of the wall outlet or the other side of the wall outlet.
Rick
Rick
You should also assign the interface to the vlan you created if it isn't already.
A swith-to-switch link should be a trunk and the cable should a be a cross-over.
int fa0/1
description Trunk to other switch
switcport trunk encapsulation dot1q
switchport mode trunk
switchport trunk allowed vlan <>
the other switch should be setup with this config as well.
Bryan,
A little clarification on your point, its really not neccssary to configure the switch ports as trunk ports.The port output shows that it is a static access port on Vlan1 and I think the original poster has to make sure that he uses a cross-over cable and it is connected to vlan1 on the other switch as well.
-amit singh
Thanks for the clarification Amit.
Well, even if your answers help to clarify, i have to abandon the idea of plugging my switch to the LAN
I will now use my lab as a dedicated test LAN, so my previous question is no longer relevant.
Though i am now trying to connect my switch to a PC via a straight-through cable:
I have setup the ethernet port on the switch in mode access.
The administrator IP (on vlan 1) is 10.2.10.200/16 (no default gateway) and the PC has an IP 10.2.10.199/16
Ping doesnt succeed...The firewall is disabled on the PC and PC and switch are connected with a straight-through cable.
Let me know if you need any other info.
Thanks again
Hi ,
Have you configured the default gateway on your pc.
Satish
No i havent, which IP should the default-gateway be?
Alan
Since your previous post indicates that both the PC and the switch management address are in the same VLAN:
the default gateway does not matter. When you get a layer 3 device into your test environment (either layer 3 switch or router) you would use the address of that device as the default gateway for the PC. As long as you are connected to a layer 2 switch and there is no layer 3 device, the default gateway is immaterial.
If the PC can not ping the switch there is some issue other than the default gateway. It would be a good start if you would post the output of show interface from the switch. Also is the PC showing link on the Ethernet connection?
Rick
Rick
Is you PC link up ? What does " show interface vlan 1 " tells you. The Vlan interface should be up/up for the same. Have you connected the PC on a port which belongs to Vlan1.
HTH,
-amit singh
Vlan1 is up, line protocol is up
Hardware is CPU Interface, address is 000d.659f.7600 (bia 000d.659f.7600)
Internet address is 10.2.10.200/16
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:04, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
3909 packets input, 661395 bytes, 0 no buffer
Received 722 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 8 ignored
2704 packets output, 154908 bytes, 0 underruns
0 output errors, 2 interface resets
The PC link is up and is connected to a port on VLAN 1
So here is the config on the first switch
show run
Building configuration...
Current configuration : 1194 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname switch1
enable secret xxx
username thomas privilege 15 password xxxx
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface Vlan1
no ip route-cache
ip http server
ip http authentication local
line con 0
password xxx
login
line vty 0 4
password xxx
logging synchronous
login
line vty 5 15
password xxx
logging synchronous
login
end
