IPsec concept help
May 23rd, 2007
I want to allow remote site to connect to me using IPsec.
I don't know the peers IP address in advance, is it possible to use rsa-encrytion keys without having the IP address?
jaffer_sathik2010 Thu, 05/24/2007 - 06:23
yes, usually in all the remote access VPN we can't predict the far end ip address.
configure your head-end device(VPN gateway)in such a way that it will connect to any range of ip addresses(0.0.0.0/255.255.255.255).
It will not affect the rsa-encryption keys...
Hope it helps.
--Jaffer
